Changed head gasket and now have oil-antifreeze mixing
Old Jan 15, 2014 | 10:36 AM
elainenseth's Avatar
elainenseth
How can you possibley put the head gasket upsidedown when it has dowels that hold it in place in 2 random spots as well as a timing chain that goes thru on one side???
Old Apr 22, 2015 | 03:54 PM
anton_baydak's Avatar
anton_baydak
Default changes head gaskets and coolant started leaking from between head and block
Originally Posted by weedahoe
IDK about the 4.7 but on the 5.7, if you get the head gaskets backwards or upside down it will leak
So I changed my head gaskets torqued the heads put everything back together. And putting coolant in the radiator it started leaking from both heads. One side more then the other. My heart dropped. What did I do wrong?
Old Apr 22, 2015 | 03:55 PM
anton_baydak
It's a 2009 ram 2500. 5.7 hemi
Old Apr 22, 2015 | 04:22 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
You probably put the one side upside down or backwards giving way to the coolant passage to leak
Old Apr 22, 2015 | 05:54 PM
chuck_hammer's Avatar
chuck_hammer
when you install New head gaskets. you make sure all openings line up.... not just the cylinders..
go purchase another set of head gaskets and start over...
and check that water passages and oil passages.. line up.
and double check that the New head gaskets are correct to your engine and year..
Old Apr 23, 2015 | 02:49 PM
anton_baydak
Default head gasket
Thank you all. I'll try it again and make sure every detail lines up
