06 ram, 3.7 v6, manual trans......high rpms at highway speeds
Old Jan 19, 2014 | 09:46 PM
  #21
Old man with a Hemi2's Avatar
Originally Posted by chuck_hammer
OK,45 years as an auto mechanic.. I know the tires are 17 inch... regardless what you say they are..
And you would be correct, because tire size is based upon rim size, not overall diameter size. Lets look at it this way, you may have 33 inch tall tires but you sure don't have them on a 33 inch wheel, and whatever wheel does fit that tire, if its a 18, its an 18 inch tire, 19..20 no matter what it is, whatever the wheel size tells you what size tire you have, the other numbers just tell you how wide and how tall the tire is, but I guarantee you, this op is correct in his statement of having 17 inch tires on his truck. I worked at a tire plant nearly 40 years and tires are sized exactly as this mechanic has stated
Old Jan 19, 2014 | 09:53 PM
  #22
Originally Posted by MikeHTally
Fortunately. It's amazing to me that in "45 years as a mechanic", you learned nothing about tires. Scares me to wonder what else you missed.
You should listen to someone that tells you of 45 years of experience. because he is absolutely correct, and you are not. Tires are not sized according to width or overall circumference or overall diameter, they are sized by rim size. If a vehicle has 17 inch rims it uses 17 inch tires as the op suggested to you but you were too into your calculations to hear him. Stop being a *****
Old Jan 20, 2014 | 08:25 AM
  #23
MikeHTally's Avatar
MikeHTally
Wow, such ignorance about tires. So if I call up a few tire shops and tell 'em I need a 17" tire, that's all the info they'll need? My Mazda's stock tire SIZE is 215/45x18. Do you really believe a 305/65x18 will fit?
Old Jan 20, 2014 | 09:41 AM
  #24
chipdogg's Avatar
chipdogg
So if you need a 20"x8"x10" box to put a part in, you just go to fedex and say "I need a 10" box???". The 17" is only a portion of the tire size, as it states it's just for a 17" rim but doesn't state the width or heighth. Cuz otherwise there are a thousand different sized 17" tires.
Old Jan 20, 2014 | 11:12 AM
  #25
chuck_hammer's Avatar
chuck_hammer
Gee, these 2 guys are going to change the "Tire"world.. and they do not work for goodyear.
and what does 245/70 means... if not the tire size ....???????
I am done here... can not teach Or talk to young people anymore.
Old Jan 20, 2014 | 11:29 AM
  #26
jessespurlock86's Avatar
jessespurlock86
Originally Posted by pizza442
I, too, have an 06 V6 Manual 6 speed w/stock 3:21 gears. Off the top of my head, I know rpm's are right on 2000 at 70 but need to check for 75 and 80 next time I go out. I don't think they'll go up to 2500 just to go up to 75 but maybe. My first thought was 'are you still in 5th gear'? And your tires are correct. There is an issue with the tach on these model years but that problem is rpm's reading too low (due to stepper motor I think) like it will drop down to 200 at idle, not higher and only at rpm's below 2000 as mine has started occasionally doing this.
When I first bought my '06 new after having an '03 V6 5speed, I would catch my Dad cruising along in 5th, forgetting this is a 6 speed!..He was killing my mileage
Let me know by email please what it reaches when you get to 75 and 80 n the highway please. jessespurlock1@gmail.com
Old Jan 20, 2014 | 12:12 PM
  #27
pizza442's Avatar
pizza442
I'm hoping to remember to look while on my way to work here shortly. Long day so I won't be at computer 'till late tonight tho...
Old Jan 20, 2014 | 12:31 PM
  #28
MikeHTally's Avatar
MikeHTally
Might as well give it up, man. Fourth-grade math and common sense are lost on 'em. They'll continue putting 17" tires on 17" wheels forever.
Old Jan 20, 2014 | 12:41 PM
  #29
chipdogg's Avatar
chipdogg
Yup, and if a customer comes in on 245/70/17's and brings a spare set of 20" rims and wants the same size overall tire, they'll have no clue what to do cuz it's not written down already.
I'll be switching to smaller rims since 2 of my chrome 20's got destroyed last week on my '04 by a stump and a boulder when my friend went off the road. Wonder how I'd ever figure out what size 17" tires to get to match the 20's???
Old Jan 21, 2014 | 02:27 AM
  #30
pizza442's Avatar
pizza442
Ok here's what I could observe: In 5th, almost 2800 at 70 almost 3000 at 75 and almost 3100 at 80. This was in 5TH gear. In 6TH was doing 75 and read 2200ish so I don't think 80 would get it to 2500; 3:21 gears and tall 6th gear don't move rpm's up much each 5 miles per hour. Seems to me your readings at 75 and 80 are basically the same as my data observed....in 5TH gear, not 6TH! So either your not shifting to 6th or your axle ratio has been changed by a previous owner...
