Rear Locking up in Reverse on 08 Ram 1500
Old Feb 5, 2014 | 11:32 AM
The Ram Man 01's Avatar
The Ram Man 01
Greetings, I have a 1500 Ram & the rear end locked up on me about 1.5 mo. ago. Lot worse. I was going down the road about 35 mph & it locked up. The large rod holding the gears together broke. What a mess. Yes the axle clips could have come loss or the big pinion nut is loose. Best let Dodge check all. Mine was covered under the epp. when mine happen. 4100.00 dollars. I had to pay 50.00. What a savings that was. A new rear end was installed.. Good luck...
Old Feb 6, 2014 | 06:13 AM
abarmby's Avatar
abarmby
@RamedHemi. I have read of the rear e- brake shoes friction material, delaminating from the shoes. Don't know if this would cause a lock up in the rear??
It'd certainly make noise in both forward/reverse directions I would assume.
Al.
Old Feb 6, 2014 | 09:22 AM
dirtydog's Avatar
dirtydog
Moderate User
Originally Posted by RamedHemi
its def the e brake i can here it in there. Will take apart and expect tonight. Rear wouldnt just happen in reverse.
Sure it could, but I do think the ebrakes are a more likely situation... Let us know how you make out.
Originally Posted by Izero
you have the lifetime powertrain warranty... let the dealer figure it out is my best advice....
Also, why did you double post?
Any repair that is found not be covered under warranty is charged a diagnostics fee.
I merged the other posts into this thread.
OP, your history shows numerous multiple threads regarding same questions. Please keep similar topics you discuss in the same thread. Thanks.
Old Feb 10, 2014 | 12:29 AM
mrfblack08laramie's Avatar
mrfblack08laramie
I have this same issue with my 08 QC 4x4. It only happens when it is wet outside and I'm backing up. My mechanic thinks the drum brake is hanging up. He told me to pull on the cable at the drum to see if it will move. Haven't done this yet. I've read that it is a pain to replace the shoes that are inside the disc rotor. By the book the rear axle needs to be pulled, but I've also read where someone did it without removing the axle.
Old Mar 4, 2014 | 10:52 AM
RamedHemi's Avatar
RamedHemi
Default Problem Found!!!
Sorry guys havent been on in a while. I found the problem!!! It was the e brakes shoe. It fell off the metal and was loose in there. I saw where it was getting wedged and stopping the truck. Ordering new shoes and hardware. Hope it isnt a nightmare job
Old Mar 5, 2014 | 03:08 AM
abarmby's Avatar
abarmby
Good to here you got it all sorted and that I was right
Al
Old Apr 7, 2014 | 06:40 AM
2001ramsport's Avatar
2001ramsport
So do you have to remove the rear axles to change the e brake shoes?
Old Apr 7, 2014 | 05:32 PM
Buggsy's Avatar
Buggsy
Pretty much. I spent hours trying to do it around the hub, and it's a b*tch. Ultimately, I paid my small town mechanic $200 to do it, and got the diff oil changed as part of the job. He did both rear parking breaks, pads, rotors, and calipers. I already had the parts purchased, all he charged for was axle seals, oil, and time.
Old Apr 7, 2014 | 07:41 PM
Easy_e's Avatar
Easy_e
I know that improvements were made to the 2006 and up rear ends, specifically the retainer clip issue.
I think it's much rarer to have the retainer clip issue with the 2006 and up.
Old Apr 14, 2014 | 11:44 AM
arvine01's Avatar
arvine01
don't open the cover,
