Dash lights and Parking lights inop
New here and having lighting issues. Was having intermittent lighting issues with my 2007 Dodge Ram Mega Cab 2wd with a Hemi. Now its happening more often. When I turn on my lights my dash lights would not work but all the instruments would work fine. The tail lights would not work but the brake lights do. I also noticed that when I turn my lights on they will flash on and off 6 times and stay off. Also my lf turn signal is doing the same ( will flash 6 times and stay off). Checked all the fuses and was going to check the relays but don't know where they are. Any help would be appreciated. Thanks
Welcome to the site. Sounds like a wiring issue and more so a broken or loose wire. Those are the worst to try to find
You can download a Service Manual from the links in my signature and see of they here as they have wiring diagrams in them
