3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Thats basically it. depending on how the lift kit raises the truck, you could probably squeeze a 2" coil spacer in there. That is only if the lift kit utilizes dropped cross members, longer springs and bigger knuckles. If you used the 6" CST kit then you are maxed out.
Ya its a RC suspension lift. The front end sits a little lower than the rear right now. So 2" spacers would be a good idea. Just worried about extending the front shocks too much
my 04 1500 is 2wd. On it I have a RC drop cross member lift with 2.5 - 3" Daystar coil spacers added up front and 3" lift shackles in the rear. On top of that I have a 3" PA BL which gives me 12" total
