Old Aug 10, 2015, 02:47 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior Guides
Print Wikipost
2007 1500 power seat
Old Feb 10, 2014 | 02:18 PM
troop90ff's Avatar
troop90ff
Default 2007 1500 power seat
anybody know what to do my power seats stop working ,,here is what has happen so far checked fuse is fine ,power to fuse block is ok .the harness to the seat itself I notice the power wire voltage goes up and down fro 3 v to 14 v .
now the truck sat for 3 weeks and battery died could this cause problem ?
any help would be great
Paul
Old Feb 11, 2014 | 09:16 AM
DodgeCares's Avatar
DodgeCares
Here's some info from the '07 DR Factory Service Manual:
DIAGNOSIS AND TESTING - POWER SEAT SYSTEM
Before any testing of the power seat system is attempted, the battery should be fully-charged and all wire harness connections and pins checked to ensure proper continuity and grounds. Also ensure that the seat being diagnosed is not jammed by foreign material. With the dome lamp on, apply the power seat switch in the direction of the concern. If the dome lamp dims, the seat may be jamming. Check under and behind the seat for binding or obstructions. If the dome lamp does not dim, proceed with testing of the individual components and circuits.
Operate the power seat switch and move the seat in all directions. The seat should move in each of the selected directions.
If the power seat adjuster fails to operate in more than one direction, proceed as follows:
1. Inspect the power seat adjuster motors to ensure the electrical connectors are fully seated to the motors. If OK, go to Step #2. If not OK, connect the electrical connector to the fully seated position. 2. Check the power seat fuse in the integrated power module. If OK, go to Step #3. If not OK, repair the circuit as necessary and replace the inoperative fuse. 3. Remove the power seat switch from the seat cushion side panel. Check for battery voltage at the fused B(+) circuit cavity of the power seat switch wire harness connector. If OK, go to Step #4. If not OK, repair the open circuit to the integrated power module as required. 4. Check for continuity between the ground circuit cavity of the power seat switch wire harness connector and a good ground. There should be continuity. If OK, go to Step #5. If not OK, repair the open circuit to ground as required. 5. (Refer to 08 - Electrical/8N - Power Systems/Power Seats/SWITCH, Seat - Diagnosis and Testing) . If the switch tests OK, check the wire harness between the power seat switch and the motor. If the circuits check OK, replace the inoperative power seat adjuster assembly. If the circuits are not OK, repair the wire harness as required.
Old Feb 11, 2014 | 10:33 PM
jasonw's Avatar
jasonw
Site Moderator
Welcome to DF. Will move you to the correct location.
For future reference:
https://dodgeforum.com/forum/dodge-r...ead-first.html
