Ball Joint squeak and Tierods catching
Old Feb 13, 2014 | 12:19 PM
BackwoodsHemiTMC's Avatar
BackwoodsHemiTMC
Default Ball Joint squeak and Tierods catching
I drive a 2003 Ram 1500 (132000) lifted and on 35s. I recently took the truck offroad and a few days after my lower ball joint on the driver's side had begun to make an annoying squeaking sound. It happens when I turn and hit any bump. I have inspected it and can see my tierod catching when I turn. I realize that these kinds of things do come with mudding and time. Last time I replaced the ball joints was 50000 miles ago. I do realize also that this is a fairly difficult and time consuming job to do alone. Any tips/methods that I could use to make this job even a little easier. Also, feel free to correct my diagnosis if you believe it may be something else (control arm,etc.) Thanks in advance guys!
Old Feb 13, 2014 | 09:39 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Its not difficult. Its not costly and it doesnt take a lot of time. I think I did mine last time in about 2-3 hours seriously. Took everything apart, pressed them out and the new ones in and bolted everything back together
