Front hitch mount for a 1500
Old Feb 13, 2014 | 07:04 PM
AAGHemi's Avatar
AAGHemi
Default Front hitch mount for a 1500
I was wondering if there is a bolt on front hitch mount for a 2005 1500. I have a winch with the hitch mount. I originally thought I would use it in the rear hitch but I don't like to idea of running the battery cable to the rear. I'm now thinking a front hitch would also be useful in other ways.
Any help would be appreciated.
Old Feb 13, 2014 | 09:37 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
No bolt on front hitch. All I have seen are custom made
weedahoe's Avatar
weedahoe
Hall of Fame Member
https://dodgeforum.com/forum/3rd-gen...h-project.html
Old Feb 13, 2014 | 09:52 PM
AAGHemi's Avatar
AAGHemi
Thanks. What about Curt 31320? Seems to be bolt on for 1500.
Old Feb 13, 2014 | 09:58 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Never seen it before, thats news to me
Old Feb 14, 2014 | 09:14 AM
Izero's Avatar
Izero
https://www.curtmfg.com/part/31320
Looks pretty nice actually.
And they make some bitchin accessories!
I'm curious how the front winch mount looks on the truck....
Old Feb 14, 2014 | 11:31 AM
Brandon_0384's Avatar
Brandon_0384
AAGHemi, I looked at a lot of different options when I thinking about a front hitch. I finally decided to just fab one up myself. There were a couple of reasons I did a custom setup.
1- I wanted the hitch to be higher. Sucks digging in the mud looking for the receiver. Fills with mud fast also.
2- by having two receivers I can install a winch and still have room for a shackle in case I need to run a 2:1 block and tackle.
3- by having the offset hitch design, I can back up a trailer using the passenger side hitch, this gives me better views of what is going on as I can see around the trailer.
4- most extreme recovery operations call for a V chain to split the load between two recovery points
Old Feb 14, 2014 | 07:49 PM
AAGHemi's Avatar
AAGHemi
Brandon, I saw the work you did on your custom hitch. Very,very nice. I would love to do my own but I'm not good at welding. I have small mig welder and need a lot more practice to make good structural welds.
Your set up is more versatile than a single hitch. Maybe after I practice more I will and another receiver to it.
Old Feb 15, 2014 | 01:37 AM
Brandon_0384
Welding is one of those skills that you need to just practice. You should be able to get a local weld shop to slap it together for you. Couldn't be more than a half hour of work.
Old Feb 16, 2014 | 12:37 AM
SquirmyPug's Avatar
SquirmyPug
AAGHemi, most smaller mig welders won't weld more than 1/8"-3/16" properly. So the pre-made hitch or going to a shop to have one made would be a good idea. If you decide to start practicing welding go over to WeldingWeb.com. Lots of info and lots of guys willing to help others learn.
Brandon, looks like you did a good job on the hitch. A few of the welds look like you could have set the machine a bit hotter though. Also, if there's room behind the plate a bar across the back making a "T" joint would help keep it from bending with a load. Some tube for the main section would have been nice.
