valve spring compressor for 4.7
Old Feb 19, 2014 | 08:40 PM
tafet's Avatar
tafet
Default valve spring compressor for 4.7
I need to replace my lash adjusters. I have been trying to find a valve spring compressor. Anyone know of a good one for a 4.7 overhead cam? Looking for one that will work with the heads installed.
Thanks
Old Feb 19, 2014 | 08:59 PM
MikeHTally's Avatar
MikeHTally
Pro Comp makes one. Price ranges from $128-$168. The OHC engine has valve lash adjustment?
Old Feb 19, 2014 | 09:34 PM
tafet's Avatar
tafet
Yep, they sure do. doesn't look to terribly difficult to change (famous last words). Need to compress the valve spring remove the follower and it right there.
Old Feb 20, 2014 | 06:28 PM
MikeHTally's Avatar
MikeHTally
... after removing the cam shaft, timing chain, etc., etc.
Old Feb 21, 2014 | 08:54 PM
tafet's Avatar
tafet
No, shouldn't have to take out the CAM timing chains and what not. The lash adjusters sit on the backside of the followers. same spot where push rods would push up on rockers on push rod V-8. Should be able to push down the valves enough to get remove the followers and the lash adjusters should pull right out of the head.
Old Feb 21, 2014 | 09:03 PM
Prismatic's Avatar
Prismatic
Some 4.7s will also self eject those followers lol
Old Feb 22, 2014 | 08:10 AM
MikeHTally's Avatar
MikeHTally
Seems that would be a bad thing.
