Engine light coming on and off 06 ram 5.7
Old Feb 22, 2014 | 09:01 AM
Hemidad101's Avatar
Hemidad101
Default Engine light coming on and off 06 ram 5.7
Ok fellow dodge guys need help. I recently replace my cat to a mnaflow high flow and a cherrybomb glass pack. And since then every now and then my check engine light comes on after a while of driving and turns off if I leave it off for a while. I thinking it just the o2 sensors I see two sensors comming right off the heads before the the cat there was nothing after it so I meed a little help. Thanks
Old Feb 25, 2014 | 01:51 AM
jasonw's Avatar
jasonw
Site Moderator
Welcome to DF. Will move you to the correct section.
For future reference:
https://dodgeforum.com/forum/dodge-r...ead-first.html
Old Feb 27, 2014 | 01:26 PM
HammerZ71's Avatar
HammerZ71
Yep, sounds like a perfect case where doing the non-fouler trick will keep that pesky CEL off...
Old Feb 28, 2014 | 07:17 AM
Hemidad101's Avatar
Hemidad101
Ya autozone said it was egr vavle but they don't know crap. Lol
Old Feb 28, 2014 | 10:31 PM
cyclone429's Avatar
cyclone429
Try disconnecting the battery, booth positive and negative than reconect in five min...Im runing true duals with cherry bombs and original o2 sensors, I get check engine when cold starting, running threw a car wash...
If this fails, than you need a scanner to read the codes, extreme could be a cam shaft sensor going..sucks that yhe yellow light tells you $$$$$ and nothing else..
