2006 power wagon sway bar disconnect
Old Mar 3, 2014 | 08:45 PM
dougwray's Avatar
dougwray
Default 2006 power wagon sway bar disconnect
I have come to the decision that I need to fix my sway bar disconnect motor. Unfortunately at the local dodge dealer, the setup will run me just over $4000, which I cannot afford at this time. The bushings where the sway bar goes into the disconnect motor are becoming very sloppy and I don't want to have to leave it this way longer then I need to. I am wondering if anyone knows if I would be able to swap out my sway bar setup for one from a regular 2500 including the link? Essentially deleting the disconnect motor for now? Hope someone can help. Thanks
Old Mar 4, 2014 | 06:16 PM
Gone Fishin's Avatar
Gone Fishin
Good chance you can swap it out, as the frames are the same. Maybe look for parts on car-parts.com
Old Mar 4, 2014 | 07:42 PM
dougwray's Avatar
dougwray
Thanks. Any help is great help at this point
Old Mar 13, 2014 | 10:59 PM
dougwray's Avatar
dougwray
As far as I can tell I'm able to do the swap. I just might have to get aftermarket links because a regular 2500 hemis are about 1/2" shorter then mine
