What should I do on my 2005 dodge ram 2500 5.9?
Old Mar 29, 2014 | 12:17 AM
mextexdodge's Avatar
mextexdodge
Default What should I do on my 2005 dodge ram 2500 5.9?
Ok so I was driving going home on the freeway and my worst fear happen... my truck stall while driving?! I had to quickly pull over to the side of the freeway before I lose speed and it happens during the night! I ignite and accelerate to pick up speed on the freeway and stall again. Re ignite and let it idle for a couple of minutes and as I try to pick up speed I can tell my truck wanted to stall again so I accelerate slow and steady at 40 mph on the freeway until I got home. Grab my OBDII as engine light symbol came on and read codes....
P0335 crankshaft position sensor A circuit
P0336 crankshaft position sensor A circuit/range performance
P0088 Fuel Rail/System Pressure Too High
Does this mean my sensors are bad and cause my truck to stall?
My truck is 2005 dodge ram 2500 5.9 cummins turbo diesel 2wd
Crankshaft Position Sensor A Circuit Malfunction
Read more at: http://www.obd-codes.com/p0335
Copyright © OBD-Codes.com
Old Mar 29, 2014 | 09:32 AM
How old is the battery?
Old Mar 29, 2014 | 11:52 AM
mextexdodge
No battery has nothing to do, their still brand new duralast gold
Old Mar 29, 2014 | 02:21 PM
dirtydog's Avatar
dirtydog
Moderate User
Stalling is your worse fear?..lol sorry, but kinda funny as there are much worse things that can happen while driving!
I think you did your homework already and have all possible answers in your links.
Old Mar 31, 2014 | 10:58 PM
mextexdodge
Man now it runs fine and the engine light went away. Solution? My motor oil was low and refill/change oil and filter. Weird truck...
