steering problems
Old Apr 10, 2014 | 02:35 PM
wyomingchad's Avatar
wyomingchad
Default steering problems
I have a 2006 Dodge Ram 2500 with 5.9 and 92000 miles. When completing a turn the steering wheel "jerks" back to the center position. The steering wheel turns smooth and I only get this feeling as it is turning back to the center position. I do not hear any noises either.
I can also feel it in the truck when turning, more so when I turn left. I would describe it as if the truck was catching on something when turning.
I do not feel any vibrations in the steering wheel when driving straight.
I checked the power steering reservoir and it is full. But I did notice the sound of air "woshing" out when I twited the reservoir cap off and not sure if this is normal.
Any advice is appreciated. Thanks
Old Apr 13, 2014 | 10:27 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
With 92k it wouldn't be a bad idea to flush the PS reservoir and cooler with new ATF4 fluid. Other that than, the PS system is very simple. All you have is the PS pump, cooler and R&P. You have a 50/50 chance of it either being the pump or the R&P
