2006 Dodge Ram 1500 HEMI
Old May 25, 2014 | 12:09 PM
lifteddodge06's Avatar
lifteddodge06
Default 2006 Dodge Ram 1500 HEMI
l need help, l replaced my Master Cylinder, Break Booster and front break calipers, pads ect. l flushed the whole break system, and added new fluid now l can not build up pressure, my rear breaks are working but the front breaks will not pump up, l bled the breaks twice and still can not pump up breaks, they fade away to nothing, all lines and good and no vacuum lines are cracked. can someone please help me.
Old May 25, 2014 | 03:37 PM
p38251's Avatar
p38251
Bleed the abs module. Sounds like you have an air pocket.
Old May 27, 2014 | 08:35 AM
ewing111's Avatar
ewing111
Could be frozen calipers too, may need a teardown and cleanup.
Old May 27, 2014 | 10:55 AM
HemiLonestar's Avatar
HemiLonestar
Did you bench bleed the master cylinder first?
