rear u joint issues
Old Jun 2, 2014 | 12:53 PM
bloodbassist's Avatar
bloodbassist
Default rear u joint issues
Hey I have an 07 2500 with the 5.9 cummins. I put a 2.5 inch lift in it and running 35's. Other than that the truck is stock, but Ive gone through at least 3 U joints on the rear end of the rear driveshaft. Any Ideas how to correct this? Was thinking that shimming the rear end to tilt a little upwards to take some of the angle of that u joint out might help. Any Idea what size shims would be used to correct the angle there?
Old Jun 2, 2014 | 04:14 PM
p38251's Avatar
p38251
that shouldn't cause angle issues. Are you using quality u-joints? Are you getting any vibration in the seat? Poss out of balance drive shaft. Is the center bearing in good shape. (If it has one)
Old Jun 2, 2014 | 05:25 PM
bloodbassist
No center bearing. And the front is joint in the rear shaft seems to be fine. Had the driveshaft balanced last fall. First joint I put in was from universal parts the second two were moog heavy duty greaseables.
Old Jun 2, 2014 | 10:23 PM
p38251's Avatar
p38251
If the front has not been replaced, I would do that one as well. I have always had good luck with NAPA precision. They are alot like Spicer joints.
Old Jun 2, 2014 | 11:13 PM
bloodbassist
I'm not sure if the front has been replaced. Its actually my dad's truck. But I do know that one is fine. Not loose at all...
Old Jun 3, 2014 | 06:41 AM
RDuck's Avatar
RDuck
Replace them in pairs. Get it balanced. And make certain the driveshaft is in phase. Check your angle at both joints. Should be close to equal.
Old Jun 10, 2014 | 06:43 PM
gunbunny2bg4u's Avatar
gunbunny2bg4u
do the angle thing. too much angle can cause them to wear out quickly. my ford back in the 80's did the same thing due to the lift I did to it. any good 4x4 shop can help you out on that.
