Differental Upgrade
Old Jun 4, 2014 | 08:54 AM
readyakira's Avatar
readyakira
Default Differental Upgrade
I'm looking to upgrade the diffs on my 2005 ram1500 quad cab. I know I have 3.73 gears. Anyone know any cheap locker sets for these? I'm not even sure what the axles are. I think the rear is the Chrysler 9.25? front I have no clue.
Old Jun 4, 2014 | 09:09 AM
ewing111's Avatar
ewing111
search for 4.56 gears or 4.10 gears on the site, you will find lots of info. Auburn is a popular choice. Truetrac is another one. Not going to be cheap though, more than 1,000 installed easy. Closer to 1500.
Old Jun 4, 2014 | 11:42 AM
readyakira's Avatar
readyakira
I can do the install. What is that front axle? is that a 44?
Old Jun 4, 2014 | 12:31 PM
HemiRam1566's Avatar
HemiRam1566
i rebuilt my rear diff in my 07 last year with a auburn carrier, works great no complaints
connor
Old Jun 4, 2014 | 01:47 PM
chuck_hammer's Avatar
chuck_hammer
if you e-mail Dodge with your vin number.. they will in a couple of days give you a complete break down of everything ordered on your truck...
engine, transmission, Drives, color, etc.
that is how I found I had a 9.25 with 3.55 gears. limited slip.
Old Jun 4, 2014 | 02:15 PM
readyakira's Avatar
readyakira
yeah I know the rear is 3.73 9.25. I have no clue what that cv axle front diff is. That is the one I want the locker in. How much was that auburn?
another question..... Did they change lug size around 2k? I am looking for another set of 17s so I have off road and street tires (gas mileage is killing me) but I think the set I found are 2nd gen and wont fit.
Old Jun 4, 2014 | 03:31 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I have a brand new set of 4.10s (rear only) sitting here n the box I will sell.
As for the differential itself, I have Auburn and some 456s
Old Jun 4, 2014 | 06:04 PM
MikeHTally's Avatar
MikeHTally
No 3.73s in the 1500s - those were used in the larger models (2500, etc.). You probably have 3.55s or 3.92s. What you upgrade to will depend on your goal.
Old Jun 4, 2014 | 06:06 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
True.
Usually if the truck came with 175 then you have 355s and if it came with 20s then you likely have 392s
But a build sheet tells all. You can also look on the sticker inside the glovebox
Old Jun 4, 2014 | 06:51 PM
readyakira's Avatar
readyakira
ok. regardless of the gears, I still dont know what the front axle is. is it a dana 44? idk. I guess build sheet. I would think all 1500 in that year range were the same other then ratio.
