02 Sensor Has Ground wire running from it
Old Jun 7, 2014 | 10:31 AM
jacksergenian's Avatar
jacksergenian
Default 02 Sensor Has Ground wire running from it
I have a 2003 Ram with a Hemi and the guy I bought it from said it has a bad o2 sensor. I'm only getting 9mpg and power is definitely lacking. I popped under the truck to take a look and I noticed a ground wire running from the o2 harness to part of the frame. Why might he have done this?
Old Jun 7, 2014 | 11:03 AM
readyakira's Avatar
readyakira
o2 sensor should only have to wires. Vref and signal. A HEUGO which acts like a o2 sensor may have more. BUT one wire is not actually just a wire and can not be spliced. Why someone would ground it makes no sense. Unless they were trying to fool the computer somehow. What size tires on the truck?
Old Jun 7, 2014 | 11:04 AM
readyakira's Avatar
readyakira
Reason I ask is when I run my 315/70/17s I only get 10. If I run the stock 245s I get 16
Old Jun 7, 2014 | 01:30 PM
jacksergenian
They are just the factory rims and tires. What could that do to fool the computer? Could he be trying to cover up a problem thats more severe than just an o2 sensor?
Old Jun 7, 2014 | 02:54 PM
readyakira's Avatar
readyakira
What exactly is grounded? one of the 2 wires? or the sensor itself?
Old Jun 7, 2014 | 03:15 PM
jacksergenian
I'm not currently with my truck, im out of state. But all I noticed when I looked at it is that there was a black wire running from where the harnesses clip together leading to the frame
