no oil pressure
I have a 05 5.7 hemi 1500. my engine has stalled twice but starts again when it cools down.it sounds like it gets no oil. pressure gauge reads normal and dipstick shows oil. any ideas? thanks
Is there overheating? You mention it will start after it cools down.
I'm not really following what the problem is. You say you think that it has no oil pressure but the gauge reads fine. What problems or issues are you actually having?
Sounds like you are being fed info from someone else? Hard to answer 3rd party info w/o knowing anything for sure.
Disconnect the oil pressure sensor by the oil filter and connect a mechanical gauge. Verify pressure. Then narrow down what the noise is and where from.
