transfer case neutral
You should just have a little button at the bottom left corner of the switch. You'll need a pen or something to press the button, but you need to shift the transmission into neutral, then press and hold the button on the switch and when it shifts, the N should illuminate to indicate that the transfer case has properly shifted into neutral as well. But of course, you could always just read the manual.
well thanks for the response. we tried that to no avail. thought there may be a trick to it. also my son bought it used and didnt come with a manual. otherwise i would have read it and skipped the post. ***
