Aftermarket lugnut help
Old Jun 29, 2014 | 01:55 PM
tantofolder's Avatar
tantofolder
Default Aftermarket lugnut help
I put Moto Metal rims on last fall and haven't needed to take them off until my shock replacement.Well one of the locking lugs was a real bear to remove,but it finally came off.It ruined the threads on that stud,so I went looking for a new(and hopefully nicer) set.It appears that the lugs I have are difficult to find and probably not very safe either.The guy at the parts store said they are "thin walled". 9/16 18 with a 3/4 hex.Most of the hex you can find for these are 7/8,but I can barely get my socket in there now... so 7/8 is too big. Can anyone help/educate me to find a replacement set?The parts guy mentioned "tuners",but I am not up to speed on this stuff.I have already swapped out my hub assembly(it needed it anyway). I am more interested in fuction than appearance right now.Thanks
Old Jun 29, 2014 | 03:00 PM
p38251's Avatar
p38251
tuner style are usually splined. I had those on my 1500. They make them in black as well. 9/16 is the size.
Old Jun 29, 2014 | 07:12 PM
fj5gtx's Avatar
fj5gtx
Can't beat mcgard... lifetime warranty, very tough and don't rust. Available just about everywhere... try Summit Racing or JEGS online.
Old Jun 30, 2014 | 05:58 PM
tantofolder
Thanks for the responses guys.
Will the splined type be stronger than a standard "thin walled" lug nut? I really like these wheels,but I don't want to sacrifice safety.
Old Jun 30, 2014 | 10:17 PM
archemedes74's Avatar
archemedes74
both are fine, I've used thin walled on a 7 second drag car with no issues (granted my studs were longer) your studs are the weakest link, and will break long before a nut would
Old Jul 2, 2014 | 04:09 PM
tantofolder
Thanks for the input archemedes74.....I feel better knowing these are capable.I had to use the thin walled ones from before(no one carried new in the size I needed),and they seem to have gone on fine.I tested them first on the old hub assembly studs without any crossthreading.
