rear axle bearing
Old Jul 11, 2014 | 08:37 AM
BAMF224's Avatar
BAMF224
Default rear axle bearing
So I'm gonna be changing my rear axle seal today. I also ordered a new bearing. Is there any way to tell whether the bearing is good or not. If the bearing is bad how do you change it. I have a manual but can't find anything on the bearing. Thanks in advance
Old Jul 11, 2014 | 09:16 AM
cd36c's Avatar
cd36c
I would recommend doing both sides. Not because they need to be done in pairs, but because you need to drain $50 of diff fluid to change a $5 seal, I usually just do both so I don't have to do the other one right away. Timewise it really doesn't take much longer either to do both instead of just one.
Axle seals often leak when your vent line is plugged, with no place to vent from the seal is the weakest point so it just blows them out. For that reason, while you are under there locate the rear axle vent line, I have no clue what you have for a truck, but usually it coming out of the T-Block for the brake lines (where the rubber hose goes to the axle and Tee's to both sides of the axle). It is the bolt that holds the T-Block to the axle, remove it, the hose, and the breather cap and check for any blockages. Clean it all up and reinstall. If you don't do this and it is plugged, you're just going to blow another axle seal right away.
Have you heard any bearing noises coming from the back while driving? That would be your first sign they are bad. The rear axle bearings aren't a common thing to fail often, so good chance they are still fine. Once you have it apart check the bearing for any roughness when turning it. It should turn smoothly with no excessive play between the inner and outer races.
If you do need to change it, you'll need a rear axle bearing puller, which you can probably rent at most auto parts stores. When pressing it back in, I often just use a socket, similar to how you'd do the seal, and just hammer it in evenly. DO NOT HIT ON THE INNER RACE! Make sure your socket only engages the outer race, you don't want to be hammering on the ball bearings or the inner race as it can damage the bearing.
Good luck, it is a pretty easy job, just take your time.
Old Jul 11, 2014 | 09:42 AM
BAMF224's Avatar
BAMF224
I appreciate the helpful advice. I did notice the other day my what appears to be vent line was broke at the hose clamp and dangling. I will definitely clean that out before I do anything else
Old Jul 12, 2014 | 06:49 AM
BAMF224's Avatar
BAMF224
Well I got an update. So I dug into everything and had a major issue trying to remove my c clip. I tried pushing on my axle shaft. I tried hitting it with a hammer. The shaft wouldn't come in far enough to release the c clip, I did remove the difference pin like supposed to before attempting it. Has anyone ran into this issue, really need the help.
Old Jul 13, 2014 | 10:20 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
If you removed the center pin from the differential, you should have no issue pushing the axle in far enough to be able to release the C clip off the axle. Use a magnet to grab the clip and pull it out.
Old Jul 14, 2014 | 08:51 AM
cd36c's Avatar
cd36c
I've never had an issue pushing the axle in. Check on the outside of the axle shaft, the part that would have to slide into the seal, is there a buildup on the axle shaft from the leaking seal? I would think the hammer would do it, but maybe try cleaning off any buildup and see if that works.
Is this on both sides or just one side?
Old Jul 14, 2014 | 08:05 PM
boosted-fc3s's Avatar
boosted-fc3s
It should slide nearly effortlessly, unless your axle is so worn that the bearings have eaten into it.
