Truck won't start wet out
Hello All,
My first post. I have 2003 1500 4wd 5.7 engine
Wouldn't start. I because I work odd hours, i couldn't stay on top of things. But I thought it was the fuel pump. So I replaced it. Ran great for a few days then wouldn't start. I have come to realize that when its raining, or say the morning dew, it won't start or has to crank a bit to start.
The only code found was for bank 1 #1 co2 sensor.
all connections look tight and the vac test passed.
Any ideas what it could be?
Extended cranking or lack of firing when moisture levels are high (i.e. high humidity, rain) indicate work spark plug wires. Yes, spark plug wires wear over time and degrade in performance. The moisture content in the air increases the resistance that the ignition system cannot overcome.
Replace the spark plug wires.
Correct me if I'm wrong, but the only spark plug wires on a Hemi of that vintage are for the secondary plugs, the main plugs are directly below the coil.
I agree, it is probably an ignition problem, unless you had a specific reason to suspect the fuel pump? Did you test pressures and see they were low? Did you test again after you replaced the pump? I doubt it is the fuel pump though.
You could try replacing the wires, it may help. Inspect the boots for proper sealing and cracks in the insulation along the wire, replace if damaged.
I don't have a pressure gauge for testing fuel or injectors.... yet
But there is plug wires on it. As far as I know they are original. I was planning on replacing the Cap, Rotor, wire and plugs with my next check.
btw... When it does crank, it sounds like it starts to kick over but doesn't.
If you haven't done any work to the ignition system in that many miles do a tune up. If it is a hemi there is no cap and rotor. Just change the plugs and wires.
Trending Topics
I didn't think any of the 5.7L Hemi engines had plug wires... they are coil on plug ignition....
If it's a 5.9L Magnum engine however plug wires & distributor would be a good starting point.....
I'd also change the spark plugs while I was in there too... Remember to use COPPER CORE PLUGS.
