Adjusting receiver/hitch
Old Jul 23, 2014 | 08:39 PM
ms9811's Avatar
ms9811
Default Adjusting receiver/hitch
My 06 2500's factory receiver seems to be drooping. It does not appear to be bent, it just looks like the angle is down a bit. I read somewhere that it can be adjusted using some combination of the three bolts that hold it to the frame. Can someone direct me to the proper procedure and specs for doing this, or let me know if there is some other way?
Thanks in advance!
Old Jul 23, 2014 | 11:43 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Sure someone didn't put too much weight on it?
I can't see how the tilt angle can be adjusted. The bolts pretty much just hold it to the frame.
Have you gotten under the truck to see about the bolt pattern?
Old Jul 23, 2014 | 11:52 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I just looked at mine and it seems on each side there is one bolt that goes up through the bed and two that can through the frame. Doesn't look like any adjustability. Maybe yours is bent.
Old Jul 24, 2014 | 12:22 AM
Will_V2Lab's Avatar
Will_V2Lab
I wouldn't see the point in being able to adjust it either. That could mean that it could come loose and adjust while towing something which wouldn't be good.
Old Jul 24, 2014 | 12:50 AM
RamRod37's Avatar
RamRod37
yeah sound's like it was over loaded and bent it
