Water Leak Into Pass Side Floor Board 04 Ram 1500 Qc
Old Jul 27, 2014 | 11:01 PM
jim1999's Avatar
jim1999
Default Water Leak Into Pass Side Floor Board 04 Ram 1500 Qc
I am having a water leak (rain water from outside) I am trying to figure out, hopefully one of you have experienced this that could shed some light on it for me, water is leaking into the pass side floorboard it is coming from the HVAC box under dash its clear water no t antifreeze, I can duplicate it if I put a hose near the lower pass side of windshield where the wiper cowl is some how water is getting into the hvac box and dripping onto carpet? any help appreciated!
Old Jul 28, 2014 | 01:45 AM
RamRod37's Avatar
RamRod37
There should be A drain hole in the cowl somewhere one p Side to drain off water in maybe stopped up with leaves or something and Letting it fill up into fresh air intake
Old Jul 28, 2014 | 09:40 AM
Buggsy's Avatar
Buggsy
I had a similar problem. Pop the screw caps off the A pillar handle. Look and see if it's wet in there. My problem was trim/weather stripping was full of gunk and pine needles. Just wiping it out seemed to have fixed the water in my floor.
These are the screw caps I am talking about:
http://www.imcoproductsinc.com/files...20%2815%29.JPG
Old Jul 28, 2014 | 11:25 AM
abarmby's Avatar
abarmby
I had the same as Buggsy except the dealer on the top of the front windscreen was compromised, letting in water.
When it rained, it dripped out of A pillar handles as Buggsy said.
I used some black RTV and resealed my windscreen.
Job done.
Al.
Old Aug 21, 2014 | 10:52 PM
Skunk731's Avatar
Skunk731
I think I have found the solution to water on my passenger side floor. My recirculation door broke so this helped me find the leak easier. I hope this helps those who have searched and can't find their leak and tried everything else. There is a windshield guide at the bottom of the windshield which makes a hole just above the air recirculation vent in which the sealant dried out. Last heavy rain, I noticed water running through the hole where the guide is, down into the air recirculation box, and down the fire wall onto the floor board. I made sure it was the guide by removing the cowl, popped off the guide, looked up from the inside and sure enough light was coming through. So I took some 3M strip caulk and put some around the plug part of the guide (just took enough and wrapped it around the base of the flat part and top of the plug part), pushed it back into the hole, and that sealed it pretty good. It rained pretty hard the last couple of days and I even poured water over it and no more leak and my floor has been dry since. I hope this helps because I tried most of everything else people posted on the forums with no luck.
(This was my post awhile back in the forum.)
