throttle position sensor
Ive read that when you reconnect the battery, turn the ignition to the run position and not start. Then quickly push the accelerator pedal all the way down to WOT and then it go all the way fully back, 5 times in 10 seconds.
Then switch the truck to off.
When you start the truck, do not push on the pedal until a stable idle.
Weeds right in just connect back up the battery but apparently, the procedure above calibrates to TPS.
It couldn' t hurt right.
Al.
Al.
Al.
Al.
