Heater problems! Help please!
My step fathers 07 quad cab 4.7. Heater only half works. Everything seems fine but the heater temp is low. The door looks to be shutting.
Any ideas on anything else to check?
Common problem maybe as my moms 99 has the same problem.
Last edited by Insanity; Oct 7, 2014 at 06:54 AM. Reason: To many views no answers . Shortened
The top hose is hot the bottom warm. I figured that would be normal due to the heat being pulled from the core.
It does look like there's a fuzzy black film on the left side of the core. Could be mildew or black foam insulation that's deteriorated. How ever the out put from the vents feel pretty good volume wise.
Auto zone says it's a ceramic switch that's under the dash held in by two screws. Because it has a smell kinda like brake pads burning. ( its not hot feeling, but the cooper connectors look like they have been ) I don't think it's antifreeze smell and theres non dripping anywhere.
Ideas?
Ideas?
Trending Topics
- Inoperative water pump.
- Inoperative thermostat.
- Pinched or kinked heater hoses.
- Improper heater hose routing.
- Plugged heater hoses or supply and return ports at the cooling system connections.
- Plugged heater core.
Possible locations or causes of insufficient heat due to mechanical problems are as follows:
- Obstructed cowl air intake.
- Obstructed heater system outlets.
- Blend-air door(s) or actuator(s) not functioning properly.
- Faulty blower motor system
- Inoperative A/C-heater control
