ABS Front Wheel Bearings
Thanks guys.
Do you have a wire coming from your front wheel bearing? if you do, you have abs! I bought timken wheel bearings and they are doing great.
I have one more question. Did you replace the bearings and not the whole assembly? If so, what tools are needed? A press?
Thanks again.
Thanks again.
You can only buy the whole bearing assembly. It's just 3 bolts on the back of the spindle. BTW, 2wd and 4wd trucks use the same part. IF you are 2wd then its super easy. If 4wd, then you have to remove your CV axle. I found it easier to break loos the upper ball joint to get enough room to pull the CV's out of the wheel bearing.
