Instrument Cluster Problems
Old Nov 2, 2014 | 08:29 PM
kbeen's Avatar
kbeen
Default Instrument Cluster Problems
Hello, we just purchased a 2004 Ram 1500. We just discovered that the instrument cluster does not light up nor does the a/c and heater control light up at night. The cluster gauges and warning lights all work fine. a/c and heater control works fine. Just no illumination at night. I have checked possible fuses. has anyone ran into this same type problem. does it sound like the cluster itself ? thank for any advice.
Old Nov 3, 2014 | 01:58 AM
Prismatic's Avatar
Prismatic
Simple things first, verify that the dimmer switch is not turned down. If not that, pull out the headlight switch and inspect the plug behind it for burned or melted wires.
Old Nov 3, 2014 | 03:30 PM
kbeen's Avatar
kbeen
Have checked the dimmer switch and all ok. The plug in the back of the headlight switch looks good. thanks for the advise.
