Alternator 160amp or 136amp
Old Nov 17, 2014 | 08:40 PM
nathangfnd's Avatar
nathangfnd
Default Alternator 160amp or 136amp
Have been having an issue with my trucks battery being dead so replaced that but didn't work so went to the auto store to get a new alternator and they have 2 options 160amp or 136amp.
The 160 is in stock but need to order 136 and guy told me you can't put the bigger one in.
I don't want to pull the one to see what size it is then reinstall it if not needed
Is there a difference of can I just put the bigger one in. Only a $15 difference but would save some headache plus I'd rather have it if I can
Old Nov 18, 2014 | 12:01 AM
HemiLonestar's Avatar
HemiLonestar
As far as I know you can. I got one from somebody out of an 04 Durango hemi. Bolted right in, easy factory upgrade.
Old Nov 18, 2014 | 09:00 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
You can put the larger amp alt in without issue as long as they are physically the same.
When my 136A died I put in a 160A. Lots of guys have.
If you want, go to www.advanceautoparts.com, add the 160A to your shopping cart, use code TRT30 at checkout for 30% off, pay for it online and pick it up in the store. That should help save you some money.
