Halo Rings to Parking Lights
Old Nov 23, 2014 | 05:35 PM
Mikeman13's Avatar
Mikeman13
Default Halo Rings to Parking Lights
Is there a way to wire my halo rings that i'm mounting in my headlights to my parking light switch... or marker lights.. or whatever you want to call them (The middle turn on the light dial).
I've tried to do plenty of research and I don't know for sure if I can do this or not. Figured i'd consult the great minds over here first.
Thanks in advance!
Mike
Old Nov 24, 2014 | 10:12 AM
Izero's Avatar
Izero
Yes you can, just tap into the front turn signal wire that controls the running light filament and run the other wire to ground.
If you're TIPM freaks out and shuts them down then wire back to the ground on the parking lights. Don't forget to use electrical tape that's rated for use under the hood.
I like the Liquid Electrical tape when splicing into the middle of a wire... seals out all the moisture and you don't have to wrap it with tape that makes the wire 10x the size.
