No power to the red wire on ignition switch.
Old Nov 24, 2014 | 07:12 PM
stratusr/t02's Avatar
stratusr/t02
Default No power to the red wire on ignition switch.
I just replaced the ignition switch, now I have no power at the red wire. What gives?
Old Nov 25, 2014 | 01:53 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Loose/bad connection? Which red wire are you testing? At the ignition?
Old Nov 25, 2014 | 03:21 PM
Izero's Avatar
Izero
Hopefully you replaced the ignition switch with the battery disconnected... otherwise you'll have activated the immobilizer, which will not allow current on the ignition wire....
We'd need some more detail on which wire and where it is to help though.
Old Nov 26, 2014 | 09:03 AM
stratusr/t02
Found the problem, looking at the wrong fuse. Thanks for the reply.
Old Nov 29, 2014 | 09:47 AM
nibroc's Avatar
nibroc
immobilizer????
