New Cherry Bomb Makes Whistle Sound
Old Jan 7, 2015 | 01:53 PM
042500moltenred's Avatar
042500moltenred
Default New Cherry Bomb Makes Whistle Sound
So, I put a new cherry bomb glasspack on my 2004 dodge ram 2500. The exhaust sounds great but every so often when I accelerate, I hear a whistling noise. It sounds like the noise is coming from the passenger side near the front passenger floor and dash area. What is causing this? Where do I look to fix this?
Also, no the noise is not the ac/heat blower!!
Old Jan 7, 2015 | 03:30 PM
So all you did was replace the muffler? Get under and inspect the exhaust system, thats where you look for starters. If you find a hole or something, fix it.
Old Jan 7, 2015 | 03:45 PM
042500moltenred
Yeah I did look at the exhaust system and no holes or anything I could see. I should also mention that the whistle does not occur when I floor the pedal or at idle. It only occurs when you put the pedal about half way down. Lastly, when I am in park and rev it up there is no noise it only occurs when driving? I am stumped.
Old Jan 8, 2015 | 01:24 PM
Daves69's Avatar
Daves69
Did you clamp on the muffler or use 360° welds? I think it possible to have a leak with the clamps.
If it's from the interior I'm not sure what is all under the dash as far as what could cause the noise. Could it be a coincidental vacuum leak that has nothing to do with the exhaust?
Old Jan 13, 2015 | 11:03 PM
Will_V2Lab's Avatar
Will_V2Lab
I had a single chamber Cherry Bomb installed on my Ram. No whistle but mine was welded onto the pipe... no clamps.
Could the whistle noise be stereo interference?
Old Jan 14, 2015 | 06:59 PM
scwpd's Avatar
scwpd
Might want to check your exhaust manifold common problem of the bolts on the rear drives side breaking or the manifold cracking
