2005 Ram speedometer inop
Old Jan 11, 2015 | 05:43 PM
bayoudevil's Avatar
bayoudevil
Default 2005 Ram speedometer inop
Help. My speedometer doesn't work and the ABS and Brake lights are on as well as check engine light. I have changed out the VSS on the diff and the two on the trans but to no avail. I have also checked every single fuse in the fuse block and they are all good. Any Ideas ???????
Old Jan 11, 2015 | 09:28 PM
bayoudevil's Avatar
bayoudevil
I have found a youtube video that shows a corroded wire and broke in two. I will check this out in the morning.
Old Jan 11, 2015 | 09:56 PM
fj5gtx's Avatar
fj5gtx
changed your rear diff fluid lately? make sure the tone ring is in perfect shape, a damaged tooth or more and the sensor flags a problem.
