Blend Door issue?
Old Jan 14, 2015 | 08:20 PM
Cavtrooper89's Avatar
Cavtrooper89
Default Blend Door issue?
I have a 2002 SLT 4 door 1500. 4.7 V8, 4x4. My heat and A/C are stuck on the vent setting and won't go to any other setting. Also, when you turn on either, the heat or a/c it makes a loud vibrating noise the higher you set the A/C to blow. Any suggestions?
Old Jan 16, 2015 | 12:20 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Well your title reads "blend door issue" and you know you have that problem so what exactly are you asking?
Go fix your blend door issue
Old Jan 16, 2015 | 08:37 AM
Cavtrooper89
I was honestly trying to figure out if that's what the problem is. I've read other threads where people say a vacuum line had come loose. I didn't know if anyone had any suggestions
Old Jan 16, 2015 | 09:43 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Not a vacuum line problem. It is a blend door problem and a common one at that. Lots of threads on here that are blend door related. I used to have two threads bookmarked from another site with full disassembly details but they don't work anymore. It's a simple fix but does require taking the dash apart
