2003 Ram 2500 5.7 strange oil leak
Old Jan 19, 2015 | 01:30 PM
graley9921's Avatar
graley9921
Default 2003 Ram 2500 5.7 strange oil leak
I am stumped ... Have an oil leak on my 5.7 hemi ... It's coming from drivers side front of engine ... Checked oil pan gasket also front and rear main seals are intact and oil free .. Looks almost like valve cover gasket but can't find a wet spot ... Not the oil filter ... I am at a loss ... I even replaced the oil pan gasket ... Cleaned every thing off wiped down and let it run in yard for 30 minutes no leaks drove it 5 mile round trip and front of engine and even engine oil on bottom of power steering reservoir... Any ideas would be greatly appreciated
Old Jan 19, 2015 | 01:43 PM
p38251's Avatar
p38251
Drive it, they put a piece of cardboard under it where you think the leak is. This will give you a more localized place to look.
Old Jan 19, 2015 | 01:58 PM
graley9921's Avatar
graley9921
I did ... It's coming from the drivers front of motor ... I wondering are there any external pressure lines for oil that might have pin hole or is that where the oil pressure sending unit might be and it's cracked? But gauge is showing normal oil pressure
Old Jan 19, 2015 | 04:13 PM
p38251's Avatar
p38251
Power steering lines? Has it had an oil change recently?
Old Jan 19, 2015 | 10:34 PM
graley9921's Avatar
graley9921
I think I have tracked it down ... After going over it again and again ... I noticed the breather tube from the filler neck to air cleaner had collapsed so I took it loose pressure washed the engine and drove it 10 miles with no more leaks .. I'll post any changes
