2007 Ram - ABS brakes not working in 4x4
Old Feb 4, 2015 | 07:45 AM
Shadow_nt1's Avatar
Shadow_nt1
Default 2007 Ram - ABS brakes not working in 4x4
I have a 2007 Ram, 5.7l, 4x4 and in icy conditions if I brake hard in 4x4 mode my ABS does not work. All the wheels lock and I'm in regular braking mode, no ABS lights are on or any other codes. Has anyone seen this?
Old Feb 4, 2015 | 12:01 PM
p38251's Avatar
p38251
I am almost certain it's normal. I had an 04 that did the same thing.
Old Feb 4, 2015 | 04:12 PM
boosted-fc3s's Avatar
boosted-fc3s
I believe it has to do with the fact in a part-time 4x4 like the Ram the front and rear differentials are locked together rotationally via the transfer case and the wheels can't turn at different speeds. ABS allows the wheels to each brake at different speeds to prevent lockup, so it wont work well or at all in 4x4 mode since the wheels can't turn at different speeds because of the transfer case.
Old Feb 5, 2015 | 09:34 AM
chuck_hammer's Avatar
chuck_hammer
Normal. transfer case and axles. its called 4x4.
all 4 wheels are powered equally. so are the braking.
