Shock ?'s
Old Mar 6, 2015 | 09:33 AM
gamjunior38's Avatar
gamjunior38
Default Shock ?'s
I just found out I need to replace my ball joints on the truck so while I have the front end apart I was going to do some other changes. Along with the ball joints I will be replacing the brake pads and rotors and I was going to change the shocks out also. So my question is what would be a good non wallet hurting set of front shocks?
Truck info:
-2005 Ram 1500 2wd
-daily driver of about 125 miles round trip a day
-front rotors going to EBC
-pads going to EBC Greenstuff 7000
-XRF upper and lower ball joints
-shocks ?
Thanks,
gam
Old Mar 6, 2015 | 09:39 AM
I've always had good luck with Monroe Sensatracks.
Old Mar 6, 2015 | 09:48 AM
p38251's Avatar
p38251
Monroe reflex
Old Mar 9, 2015 | 08:35 AM
gamjunior38
Thanks, I picked up a pair of the Sensatrac's and will see how they do. On a side note is there a braided stainless steel brake line kit for the 2wd or will the 4wd kit work?
http://www.summitracing.com/parts/rus-694510
Didnt know if the 4wd kit would be too long or not. I figured I would change the lines out also when I upgrade the brakes.
Old Mar 9, 2015 | 01:32 PM
gamjunior38
Well just found out from Russell tech that the Russell kit wont work and that they don't have a kit for my truck.
Old Mar 10, 2015 | 07:33 PM
Hjlancas86's Avatar
Hjlancas86
If you could get some Bilsteins I would go that route, my buddy has them on his truck and what a difference!
