v10 engine swapping, from 1995 into 2002, what all will I have to change wiring wise
Old Mar 8, 2015 | 10:12 PM
Wyspky's Avatar
Wyspky
Default v10 engine swapping, from 1995 into 2002, what all will I have to change wiring wise
I have a couple of questions actually;
First the 1995 has a different set of plugs so I know we have to swap the wiring harnes which means we will have to take some things off the 2002 and put on the 95 engine. Will I need to change the injectors also, and can anyone tell me what else might need changed?
Second, the 02 engine is seized tight, with auto trans, can only get to the bottom torque converter bolts even with the engine out, are there any tricks to getting to the top ones?
Thanks for any help.
Old Mar 8, 2015 | 10:41 PM
Probably all the extra sensors test the 2002 has. The 95 is OBD1, won't have all the necessary sensors to keep the computer happy.
Old Mar 9, 2015 | 12:06 PM
Wyspky's Avatar
Wyspky
How about the injectors?
Old Mar 9, 2015 | 12:07 PM
Wyspky's Avatar
Wyspky
Btw, thanks for reply
