Need help with wiring overhead console from scratch
3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Hello everyone. I need a little help please.
I have seen several install posts but nothing about wiring.
I do not have any wiring going to the area where the console should be.
I have attached a few pics. The only wire that goes from the connector in the A-pillar goes to the middle dome light and I assume to the 3rd brake light and cargo light.
So, does anyone have a wiring diagram showing which wire is which in the A-pillar? Also, which wire connects to what in the overhead console.
The overhead console wires are: Pink, Yellow with black and Yellow with green. These are for the lights.
For the EVIC: Blank, red, white with orange, white, black, blank
Anyone know which wire goes to where? Thanks
Upper wire connector going from the A-pillar to the headliner (and the dome light and to the back of the truck)
Actually, I was able to solve this.
On the connector, the pins to tie to are 2,5,10, 11 and 12. I was able to get a service manual and look up the connections.
