How urgent is a small radiator leak?
Old Mar 24, 2015 | 01:28 AM
swamper's Avatar
swamper
Question How urgent is a small radiator leak?
found a dime size leak on my driveway today from my radiator seems to be leaking on the bottom.should I worry about it or is there a way to seal it?or do I need to buy a new one?how much does a new radiator cost?
Old Mar 24, 2015 | 06:42 AM
There are tons of automotive parts websites you an easily search yourself for the cost of a replacement radiator. Keep an eye on the level and refill if it gets low. Find where the leak is coming from. May be a hose, water pump, etc. if you just throw parts at a problem without knowing what the problem is, costs can add up real fast.
Old Mar 25, 2015 | 02:44 AM
swamper's Avatar
swamper
price they gave me today at autozone was $165 bucks for a new radiator.by the way it is the radiator its not a hose or the water pump I can see where its leaking from,guess ill put it on when it comes in had to order it.thanks
Old Mar 26, 2015 | 04:20 AM
JoshSlash87's Avatar
JoshSlash87
Its only urgent if you neglect keeping it full, your temp gauge will tell you how urgent the problem is, if you run hotter than normal its urgent, means the leak got bigger. You should be fine as long as you check the cap each day before you start it and make sure the radiator level itself its up to or near the top and make sure the overflow is half full. A spot the size of a dime would probably take a few days to make itself a concern with no attention (meaning not keeping it full).
My 98 Neon radiator leaked and even steamed slightly, kept up on checking the level & drove it 5 months that way, beating the crap out of it to work before I finally broke down and bought a bottle of the $8 copper stop leak and haven't had a problem since.
