Fluctuating idle.
Old Apr 8, 2015 | 07:26 AM
Sdupuy01's Avatar
Sdupuy01
Default Fluctuating idle.
02' 4.7 w/ 166k, my idle has been fluctuating from almost stalling to about 1500 RPM's. I recently cleaned the TB and changed the IAC and TPS. No differance. i have done a visual check for any vacuum leaks and I didn't see anything, but that's not saying there isn't one. Any other ideas. If it helps, this started when I had a cracked head putting coolant onto two of the cylinders that has since been repaired. Not sure if related though.
Old Apr 8, 2015 | 09:33 AM
SmokinJoe02's Avatar
SmokinJoe02
How long since you changed the plugs? PCV valve?
SJ03
Old Apr 9, 2015 | 05:15 PM
Sdupuy01's Avatar
Sdupuy01
The plugs and pcv valve were changed when I changed the head last weekend. I have also changed numerous other thing such as some coil packs and some injectors. The surging idle was happening before I did the top end over haul and I was hoping the over haul would have fixed it. The truck runs like a champ now but I just have to get the idle straight before it kills my tranny.
Old Apr 9, 2015 | 08:43 PM
p38251's Avatar
p38251
Are you getting any codes?
Old Apr 10, 2015 | 04:50 PM
Sdupuy01's Avatar
Sdupuy01
0 codes. I'm going to spray some ether or WD on the vacuum lines later to see if a line or rubber is cracked.
Old Apr 11, 2015 | 08:15 AM
HammerZ71's Avatar
HammerZ71
I'm betting vacuum leak, although you may want to take a good look at your plug wires...
Old Apr 11, 2015 | 10:32 PM
Sdupuy01's Avatar
Sdupuy01
Well I checked all of my vacuum lines first with a spray bottle filled with soap and water and then later on with ether. I didn't see anything or hear anything while checking them that would make me think I had a leak. And about the plug wires.... The 4.7 has coil over plugs, no wires. I have replaced EVERY coil and plug and still does the same thing.
Old Apr 12, 2015 | 11:20 AM
Sdupuy01's Avatar
Sdupuy01
Winner winner chicken dinner..... After weeks of racking my noggin, it seems as if the MAP sensor was the problem. I changed it last night but never started the engine because it started raining. Went this morning to make groceries and I had to make sure I was in the right truck. The engine ran awesome, idle was perfect. Thanks to everyone for all the help.
