04 hemi noise??
Old Apr 15, 2015 | 04:57 PM
Hjlancas86's Avatar
Hjlancas86
I have a better video I am going to post in the next half hr
Old Apr 15, 2015 | 05:09 PM
Hjlancas86's Avatar
Hjlancas86
https://www.youtube.com/watch?v=yO6v...ature=youtu.be
Here is another video I made today when I went through a drive through. You can hear it better because the noise is bouncing off the wall.
Old Apr 17, 2015 | 05:30 AM
abarmby's Avatar
abarmby
Sounds exactly like mine. It's the Hemi tick.
Al.
Old Apr 29, 2015 | 01:38 PM
Carlos Brown's Avatar
Carlos Brown
Hjlancas86,
I have a 2003 2500 QC 5.7L that I purchased new. The truck now has over 310K miles on it. After some time the truck developed noises, at least one which I would describe as the Hemi tick. As time went on, the noises became more numerous and louder... Most of them you simply write off, but the truck finally got to the point where it idled poorly and developed a loud clacking noise. I tried several simple things that did not improve the situation at all.
So, I finally decided to tear into the exhaust manifolds and bolts. Well, each side had three broken bolts and the driver side actually had a bolt completely missing. I decided to start on the passenger side thinking that it would be the easiest to repair, only to find that the driver side was much easier since the engine is offset to the passenger side. After replacing all of the studs, bolts, and gaskets, the truck sounds like it did when I drove it off of the showroom floor... Not even a Hemi tick!
I did notice that the new gaskets are much different than the old ones. The old ones were a very thin multiple layer metal gasket. The new gaskets are three times thicker than the old ones and are comprised of a metal layer with other gasket materials...
I have heard all sorts of diagnoses for the engine noise, but when a 310K mile motor ends up being as quiet as the day it was purchased, this is worth a look!
Regards,
Carlos
Old Apr 29, 2015 | 07:11 PM
Hjlancas86's Avatar
Hjlancas86
Originally Posted by Carlos Brown
Hjlancas86,
Regards,
Carlos
Thanks, I will try that to see if it helps. i hope it does help and will be a cheaper fix.
