spider gears replacement
Old Apr 16, 2015 | 01:54 PM
adkeillor4@gmail.com's Avatar
Default spider gears replacement
Hello all. I'm Adam. I have a 2004 1500 ram. 5.7 hemi. With RWD. I'm going to be replacing the*spider*gears. I have done some looking in to it and I'm not sure if I need to mess with the shims. I thinking the shims are if I change the ring gear. Any help or advice would be great.
Old Apr 16, 2015 | 04:32 PM
p38251's Avatar
p38251
Why just the spider gears?
Old Apr 16, 2015 | 04:37 PM
When I was changing the axle bearings. I notice that some of the teeth had chunks missing out of them. Also I'm going to sell it. I don't want to put a lot of money in to it that I will not get back. Just enough to fix it right.
Old Apr 18, 2015 | 03:49 PM
Largefarva's Avatar
Largefarva
You should be able to simply swap them out, there will be one shim under each gear, just reuse them.
Old Apr 18, 2015 | 03:53 PM
Thanks frava. That is what I was thinking.
