Key Fob Issue
Old May 18, 2015 | 09:10 PM
DavidLaFrance's Avatar
DavidLaFrance
Default Key Fob Issue
just bought a 2003 Dodge Ram 1500 Laramie.
the one key fob they gave me worked when I got the truck...the next day (after some stereo work) the remote only works if the truck is on. I still have the stereo and overhead light console removed. Is that causing the issue?
Sorry if this is a rookie question...tried searching under a couple of different queries, but no luck
Old May 19, 2015 | 01:24 PM
MikeHTally's Avatar
MikeHTally
Haven't heard of that one. The fob receiver is in the roof above the console, I think. Maybe you loosened an always-hot lead (or moved one)?
Old May 20, 2015 | 07:25 AM
DavidLaFrance
Default fixed it
Found the problem...
covered 20amp fuse in fuse box blew. Its the IOD (Ignition Off Drain) fuse.
Replaced the fuse and it's good to go.
Old May 20, 2015 | 05:18 PM
chuck_hammer's Avatar
chuck_hammer
a good reason to remove the positive battery cable First.. just saying
Old May 21, 2015 | 01:31 PM
DavidLaFrance
Default yep
First time I've run in to a problem not disconnecting the battery.
Lesson learned.
