06 Dodge Ram 1500 ABS & Brake lights
Old Jun 19, 2015 | 09:04 PM
dmt2358's Avatar
dmt2358
Default 06 Dodge Ram 1500 ABS & Brake lights
The ABS & Brake lights come on at random times on the dash. Can anyone tell me what might be causing this please?
Old Jun 22, 2015 | 11:02 AM
DodgeCACares's Avatar
DodgeCACares
dmt2358,
I've attached some info. from the owner's manual which may help explain what you're seeing on the dash.
If you notice any reduced braking performance etc., please notify your local Ram dealer and have it looked at.
Check out pages 229-230 for further reading.
Old Jun 22, 2015 | 04:09 PM
dmt2358's Avatar
dmt2358
Thank you, I'll check through those pages. The brakes are still working fine, that's what was puzzling me about the lights doing what they are.
Old Jun 22, 2015 | 05:22 PM
p38251's Avatar
p38251
Check for play in the front wheel bearing. Jack and push and pull on the top and bottom of the tire.
Old Jun 24, 2015 | 04:47 PM
DodgeCACares
dmt2358,
You're welcome!
An ABS service light may come on so that could be what you're seeing.
If that's the case, the brakes will continue to work however without the advantage of ABS.
