driver side cv axle....
Old Jul 26, 2015 | 07:18 PM
valis.block's Avatar
valis.block
Angry driver side cv axle....
So two months ago it snowed and had to use my 4 wheel drive to get around post and ended up somehow blowing out my front differential.. had it along with my driver side cv axle replaced and now two months later i noticed the seal going into my diff popped out took my truck in to get a leveling kit put on and asked if they could pop it back in and was told it only pops out if something is wrong took it back to the place i got the repairs and they replaced the "faulty" cv axle they put in according to them.. drove it five miles to a gas station and checked it out while i was pumping gas.... 1. the boot closest to the wheel was already cut leaking grease 2. I put it in four high and drove in a circle just to make sure it had proper function but when i turned to the left there was tension then a pop and what do you know the seal was out and my cv has a ton of play once again taking back in tomorrow since they have yet to fix the problem from 2 months ago but was wonder if y'all had any ideas why it would keep doing this?????
Old Jul 26, 2015 | 11:51 PM
HammerZ71's Avatar
HammerZ71
Nothing difficult about cv shafts replacement. Have used dozens of Cardone shafts on Ram 1500s, ain't had a bad one yet. Only thing I can think of is they aren't catching that c clip when they are inserting the inner shaft...
Old Jul 27, 2015 | 01:04 AM
valis.block
i take it in tomorrow ill mention it thanks
Old Apr 11, 2020 | 02:43 PM
redbear247's Avatar
redbear247
If it's an automatic check the throttle valve and torque shaft assembly. Seems strange but I believe they were recalled and updated and they tend to cause problems at zero throttle for the most part. I'm not an expert. It just seems that I've come across that at some point. It would explain why it goes away with the throttle on and that it comes and goes with tire rotation and the like because that would disturb it enough to temporarily jar it into correct position. They tended to cause an issue with downshift from four to three after the throttle was released. Usually the sound seems to come from the driveshaft.
Last edited by redbear247; Apr 11, 2020 at 02:46 PM. Reason: Accidentally posted to the wrong thread
