new brakes and still bouncing while braking
Old Aug 28, 2015 | 04:45 AM
swamper's Avatar
swamper
Question new brakes and still bouncing while braking
I put new rotors and pads on my truck and my front right wheel is still bouncing while im braking.what could it be?what should I check next?
Old Aug 28, 2015 | 07:46 AM
If the wheel is actually bouncing up and down when braking it's something more than a warped rotor.
Old Aug 28, 2015 | 01:33 PM
TejasMtnBiker's Avatar
TejasMtnBiker
yes they can be brand new but still warped, sometimes its best to have a final pass done if you buy the 39.00 units
Old Aug 29, 2015 | 06:41 AM
Gone Fishin's Avatar
Gone Fishin
It's also possible that the shocks are bad, or going bad.
Old Aug 29, 2015 | 11:55 AM
swamper's Avatar
swamper
I was thinking that to but if it was the shock why would it only do it when the brakes are applied?
Old Aug 29, 2015 | 01:51 PM
HammerZ71's Avatar
HammerZ71
Constriction or gunk in the brake lines can cause it. Will lead to the calipers to pulsate. Did you bleed them when changing the rotors/pads???
Old Aug 29, 2015 | 02:55 PM
66three83's Avatar
66three83
I had a slipped belt in a tire that I could only feel during braking. Slight bump you could only see when you jacked the truck and spun the tire.
