2002 4.7 fisherchow
Old Aug 28, 2015 | 02:57 PM
fisherchow's Avatar
fisherchow
Cool 2002 4.7 fisherchow
I have a 2002 ram 1500 with a 4.7 engine with a bad block. a friend had a 2005 ram roll over with a 4.7. which he had pulled out and sold it to me. what will I have to do to put this engine in my 2002. the truck actually belongs to my grandson. need help.
Old Aug 28, 2015 | 03:24 PM
HammerZ71's Avatar
HammerZ71
You're pretty much gonna need that rolled truck as a donor. 1999-2002 4.7 is jtech PCM, '03-'07 is NGC ( 3 plug vs. 4 plug is easiest way to know what you have). You'll need PCM and wiring harness. Also, I think you're gonna find that '02 has 16 tooth crankshaft ring gear, '05 has 32 tooth tone ring.
Old Aug 28, 2015 | 05:57 PM
fisherchow's Avatar
fisherchow
Default help 4.7
I have the 2005 roll over. it is a 4 plug, the 2002 is a 3 plug, is it possible to change out the harness. and how would I get that info.
Old Aug 28, 2015 | 06:45 PM
HammerZ71's Avatar
HammerZ71
Pick up a factory service manual.
I've done 4.7 and 4.7 HO rebuilds but never an engine swap, so maybe someone who has will chime in. But this is what I do know.
The '05 is the last PCI Bus, so you're good there. However, as I stated, the '02 has a J Tech PCM - three wire because that truck has a separate, dedicated TCM (transmission control module). The '05 has an NGC PCM and has four wires because the TCM is integrated within it. This is why I believe you'll need to use the wire harness out of the '05.
I also know you'll have to have the dealer program the '02s VIN into the NGC or the sentry key immobilizer module will prevent the truck from starting.
Also, if you are in an inspection state you have another major hurdle. To pass smog, you'd have to have a J Tech engine. The NGC is not compatible with your emission equipment and will always generate a CEL unless you get a custom tune.
That's about all I have off the top of my head. Good Luck...
Old Aug 28, 2015 | 06:51 PM
HammerZ71's Avatar
HammerZ71
Oh and your "timing issue" you mentioned in the other thread goes back to what I said about the different tone rings between the years. The J Tech is expecting the 16 tooth which tells it when the compression stroke hits TDC, that '05 has a 32 tooth ring and reports when every stroke hits TDC.
Hope this helps some...
Old Sep 1, 2015 | 01:43 PM
HemiLonestar's Avatar
HemiLonestar
Or take it apart and put the 02 crank wheel on the 05 engine.
