A/C not blowing
Old Aug 28, 2015 | 04:46 PM
dm33buckeyes's Avatar
dm33buckeyes
Default A/C not blowing
My A/C is not blowing, I took the blower out and turned the car on and it spins fine. I had some gauges on the low pressure line and it reads in the green about 34PSI. I can hear the clutch clicking on and off. I checked the cabin air filter and its a little dirty but not clogged up. Today it was blowing but you had to put your hand against the vent to even feel a little bit. Now its not blowing at all. The heater also doesnt blow any air through the vents. Could there be a clog somewhere? If it was the A/C compressor, wouldn't it blow just not be cold? Thx
Old Aug 28, 2015 | 05:01 PM
p38251's Avatar
p38251
Sounds like you may have a broken blend door.
Old Aug 29, 2015 | 09:16 AM
Joey Caddell's Avatar
Joey Caddell
Maybe youd know how mice are getti g in my 2010 dodge..is ther a place i can put a screen where outside air enters?
Old Aug 29, 2015 | 10:16 AM
p38251's Avatar
p38251
Check underneath where the evap core drain tube comes out. Mice can get in to the smallest of spaces.
