Stalling randomly
So truck sometimes stalls only when decelerating fast. i noticed if a/c is on it seems like it wants to more. more or less if im cruising and have to brake hard. Ive scanned for codes and nothing. I dont know what to look for. Its hard to explain but maybe someone out there knows what up.
I got a 2006 Hemi 5.7L with 277000km. Thanks!!!! |
When's the last time you did a full tune up for her? Including cleaning the Throttle Body and EGR Valve?
Originally Posted by KasperR34
(Post 3263310)
Take off the throttle body and clean the whole thing. If it hasn't been cleaned thoroughly before, you will be surprised how nasty it is. As for the EGR valve, it is not unheard of for it to go bad, especially if the rest of the system is really dirty.
Originally Posted by Chet Ubetcha
(Post 3263461)
Yes, use brake cleaner, just be careful not to get it into the TPS module on the side. Check this link out from when I did mine about a month or so ago:
https://dodgeforum.com/forum/3rd-gen...ttle-body.html As for the EGR valve, yes, it can go bad in a year. It's not exactly unusual, though you'd expect a new part to last longer. I think the first time mine lasted a little over a year between going out. This current one lasted about three years until it was replaced about a year ago. Search out some info on the EGR valve here. As for the EGR delete, I'll let someone else take that one. I'm curious, too. |
Mine did kinda the same thing. I figured out I broke a plug on top of my compressor line changing the oil one time. It would short out on the compressor and stall out. There's 2 plugs there might want to check them out.
There's also a vacuum line coming off the top of the brake booster that tends to rub and it you get a hole in it will cause just enough vacuum leak to stall at very low rpm. Just another thing you can check...
So cleaned the throttle body, pretty dirty. Checked brake booster plugs, they still there and tight. A/C Compressor line are fine, I put a hose over top, years ago, to prevent rubbing thru. Cleaned air filter just cause, wasn't that dirty.. I'll see if any change happens.
Is there a way to test EGR or clean it? |
I haven't watched it, so I don't know if it will apply to our trucks, but if you look up ChrisFix on YouTube, he has a video about cleaning the EGR valve. His stuff is usually pretty good.
